Tracking down a Broken Guidance System in ARC Raiders can take several raids, especially if other players are also targeting Exodus loot zones. However, focusing your efforts on Rocket Assembly in ARC Raiders BluePrints Spaceport or the Assembly area in Stella Montis will significantly improve your chances.
For safer runs, Spaceport is generally the better option, especially for solo players. If you're confident in PvP and want access to multiple loot routes, Stella Montis can provide higher potential rewards-just be prepared for competition.
With careful planning, smart routing, and a bit of luck, you'll eventually secure the Broken Guidance System needed for your crafting and Expedition progress.
If you've been scouring the wastelands in ARC Raiders looking for a Camera Lens, you're not alone. This Uncommon Security item has a habit of appearing when you least expect it-until you actually need it. Whether it's for crafting, upgrading gear, or completing a specific quest, tracking down a Camera Lens can suddenly feel far more difficult than it should be.
The good news? There are reliable hotspots where your odds improve significantly. In this guide, we'll break down exactly where to search, which maps give you the best chance, and how to approach each location safely.
Understanding the Camera Lens
The Camera Lens is classified as an Uncommon Security item. That classification is important because it determines where it most frequently spawns. Any map featuring the Security marker icon has the potential to drop Camera Lenses in its loot containers.
Most regions in the game support Security loot spawns-with one notable exception: Buried City. Outside of that map, you'll always have at least some chance of finding a Camera Lens in containers, lockers, crates, or even occasionally sitting out in the open.
However, not all maps are equally efficient when farming this item.
Best Maps for Farming Camera Lens
If your goal is to maximize efficiency and minimize unnecessary risk, focus on these three maps:
Dam Battlegrounds
Stella Montis
The Blue Gate
While Spaceport technically includes a Security loot section at the Launch Towers, it's generally not recommended for Camera Lens farming. The Launch Towers are positioned near the center of the map, making them a high-traffic area. That means:
Increased player encounters
Heavy ARC patrols
High likelihood that the area has already been looted
Unless you spawn nearby and arrive early, you're better off choosing one of the three primary farming maps listed above.
Dam Battlegrounds Camera Lens Locations
Dam Battlegrounds offers two strong farming zones:
1. Hydroponic Dome Complex
This large, multi-dome structure sits near the center of the map and contains numerous loot containers. The density of searchable objects here significantly increases your chances of finding Uncommon Security ARCR Items like the Camera Lens.
The domes are spacious, with multiple entry points and internal pathways, allowing flexible movement. However, expect resistance. ARCs frequently patrol the area, and its central position means other players may rotate through.
2. Control Tower
Also centrally located, the Control Tower is another high-value loot site. To access it properly, you'll want to approach from the southwest. This route offers the safest and most consistent entry point.
Like the Hydroponic Dome Complex, the Control Tower contains multiple containers and Security loot opportunities. It's dangerous-but worthwhile. If you're confident in your combat skills and situational awareness, Dam Battlegrounds can be one of the most consistent Camera Lens farms in the game.
Stella Montis Camera Lens Locations
When playing on Stella Montis, focus primarily on the upper level of the map.
The Lobby (Top Layer)
The Lobby is marked as a Security loot area and serves as the primary farming zone for Camera Lenses here. This location is especially valuable because it spans four separate floors, each packed with buy ARC Raiders BluePrints searchable containers.
MMOexp ARC Raiders: Stella Montis Camera Lens Locations
Dúvidas de como utilizar o forum? Poste aqui sua dúvida que o mais breve possivel, seu problema será solucionado.
1 mensagem
• Página 1 de 1
1 mensagem
• Página 1 de 1
Voltar para “Dúvidas sobre Utilização do Forum”
Ir para
- Institucional
- ↳ Institucional
- ↳ APVWQ - Associação dos Proprietário de VW Quadrados
- Regras Clube do Gol Quadrado
- ↳ Atenção para as regras.
- Apresentação - Novatos
- ↳ Apresente-se aqui.
- Principal
- ↳ Dúvidas sobre Utilização do Forum
- ↳ Avisos, Criticas e Sugestões.
- ↳ Principal
- ↳ Midias - CdGQ!
- ↳ Tunel do Tempo
- ↳ DIY - Faça vc mesmo.
- ↳ Ação Social - CdGQ!
- ↳ Carros ROUBADOS
- ↳ Topicos Bloqueados
- Garagem Técnica
- ↳ Motor e Cambio
- ↳ Motor Refrigerado a "Agua" - AP
- ↳ Motor Refrigerado a "Agua" - CHT
- ↳ Motor Refrigerado a "AR"
- ↳ Cambio
- ↳ Suspensão / Freio
- ↳ Carburadores
- ↳ Injeção Eletronica
- ↳ Preparação de Motores
- ↳ Rodas/Pneus
- ↳ Manutenção Geral
- ↳ Parte Elétrica
- ↳ Segurança dos Carros
- ↳ Acervo Tecnico
- ↳ Originalidade / Colecionadores
- ↳ Lataria / Pintura / Estruturas
- Area Comercial
- ↳ Classificados Veículos - VENDA
- ↳ Classificados Diversos - VENDA
- ↳ Produtos do Clube
- ↳ Empresas Parceiras
- Galeria de Fotos e Videos
- ↳ Galeria Membros - VW GOL AR/BX/CL/GL/STAR/LS/GT
- ↳ Galeria Membros - VW GOL GTI
- ↳ Galeria Membros - VW GOL GTS
- ↳ Galeria Membros - VW GOL COPA
- ↳ Galeria Membros - VW Voyage
- ↳ Galeria Membros - VW Saveiro
- ↳ Galeria Membros - VW Parati
- ↳ Galeria Membros - VW Passat
- ↳ Galeria de Eventos
- ↳ Galeria Geral
- ↳ Galeria Diversos Carros
- ↳ Videos Encontros - CdGQ!
- ↳ Videos Diversos
- Aplicativos CdGQ!
- ↳ CdGQ! Mobile - Android
- ↳ CdGQ! Mobile - iPhone
- ↳ CdGQ! Mobile - Chat
- Som Automotivo
- ↳ Som Automotivo - Duvidas e Informações
- Legislações
- ↳ Leis de transito
- ↳ Inspeção Controlar SP
- Off Topic / Assuntos Gerais
- ↳ Diversão / Bate Papo / Assuntos Gerais
- ↳ Músicas
- ↳ CdGQ! - GIRLS
- Encontros do Clube
- ↳ Encontros 2018
- ↳ Encontros 2015
- ↳ Organização Filiais CdGQ!
- ↳ Encontros 2022
- Filial e Clubes Parceiros
- Filial CdGQ! - PR
- SÓCIO - CdGQ! 2014
- ↳ Filial CdGQ!-Campos Gerais/PR
- ↳ Filial CdGQ! - DF
- ↳ Filial CdGQ! - SC
- ↳ Filial CdGQ! - RJ
- ↳ Filial CdGQ! - RS
- ↳ Filial CdGQ! - MG
- ↳ Filial CdGQ! - AL
- ↳ Filial CdGQ! - PA
- ↳ Filial CdGQ! - RO
- ↳ Filial CdGQ! - AP
- ↳ Filial CdGQ! - RN
- ↳ Filial CdGQ! - Baixada Santisa/SP
- ↳ Filial CdGQ! - Vale do Paraiba/SP
- ↳ Filial CdGQ!-OZ Zona Oeste/SP
- ↳ Filial CdGQ!-ZS Zona Sul/SP
- ↳ Filial CdGQ!-ZL Zona Leste/SP
- ↳ Filial CdGQ!-GRUZN Zona Norte Guarulhos/SP
- ↳ Filial CdGQ!-ABC/SP
- ↳ Filial CdGQ!-Franca/SP
- ↳ Filial CdGQ!-Campinas/SP
- ↳ Filial CdGQ! - AM Manaus
- ↳ Filial CdGQ! - Sorocaba/SP e Região
- ↳ Clubes Parceiros
- Administração
- ↳ ADM CdGQ!
